System options, file locations not updated to install directory...
Discussion created by Guest on Nov 25, 2006
Latest reply on Dec 2, 2006 by Jim Hilgenberg
I guess I should have been more clear. When I said settings I actually meant file locations, which is what he was actually asking about. Nonetheless, I still don't like how it installs. SW should not point to an older SW file location for installs. This has become a pain because if you uninstall your old version after you have installed your new version you lose those file locations. I ran into this when building an image. When I built the image for 2007 it used my 2006 file locations. I decided to remove my 2006 and when I installed 2007 from the image I had no icons, and the background colors were black with black text. I had to rebuild the image and make sure I went through every setting to make sure nothing was pointing to the older version.
Dan
