Example of list...
Type Number Customer
33456 Johnsons Wax
H512A Tim Hortons
I need a list with 150 type numbers with the corresponding customer.
When I select the Type Number I want the customer to be filled in automatically. (see atached jpg file)
Users do not normally know the customer for all Type Numbers.
How can I do this in EPDM ?
You can use the alias but since you have multiple numbers for the same customer you need to add an Unicode Control Character. Right click in the alias field and select insert unicode control character from the drop down. You have a choice of 17 different ones and you can add them to different spots in the customer name if you need more. This will NOT insert a space but instead puts nothing that takes any text character posittions but does make a unique change to the text field. It works becuase there are a couple places that I have had to use this.
