Hi Guys,
I want to auto assign part number to SW documents using different serial numbers for example SW part is SW-1234, assembly is ASM-1234, drawing is DWG-1234 when I change the transition in the workflow.
Is there a way to do it? Currently, the COPY TREE command can do it but I do not want to make a copy of the SW documents but rename the existing documents.
Thanks for the help!
As far as I know, Property Links Professional has this functionality (and more).
http://www.javelin-tech.com/main/products/propertylinks.htm
They call it "Automated Part Number Generator"
