I've created a static study and when I tried to plot the pin/bolt check plot the following message appeared "strength data has not assigned for any bolt/pin connectors". I can't understand what I'm doing wrong...
Hi.
To do the bolt/pin check plot you need to assign properties to the bolt/pin connector (tensile stress area and strength). See picture of below. These options are found in the propertymanager for the connector.
Joe also made a helpful post about bolt connectors on the forum:
There you can find links to PDF with stress area and strengths for different sizes of bolts. Check it out.
Can you show your bolt connector propertymanager?
