hi guys
i am having a frustratung time with photoview render using a black reflective floor. i use a standard 3 point beige for lightining and then added floor appearence as black reflective but the photoview render shows no black reflective surface not even reflective. the floor reflections square is not ticked and is not accesible in the edit environment menu. so i tried adding a large floor (as a part) in the assembly below, mated to the floor plane so as to act as a floor for this and set the properties to reflective black floor and tried high gloss plastic too. nothing gives a black reflective surface. tried changing light orientation too. any tips ?
thanks
it sounds like you know what you are doing but did you remove the floor shadows once you put in the floor stucture? Also did you set the floor location to the bottom of the floor structure?
