I could use a little help w/ an assembly.
I've made a multi-body part (Part A). One body (Body B) in the multi-body uses the fill pattern feature to array blind holes into Body B. I inserted Body B into a new, separate part (Part C). Part C is used in an Assembly (Assembly D). Assembly D is composed of Part C and a new part, Part E. I would like to use the Feature Driven Componet Pattern to array Part E onto Part C at each of the blind holes. However, the fill pattern feature is only associated with Part A, not Part C. Part C seems to be just a simple model w/o any feature details. Any ideas?
That is as designed. When you Insert a Part into another Part you do not get the feature tree. You are bringing in the solid body only.
Why do you need such a complex modeling structure? Seems a bit convoluted.
Hard to judge since we only have a word description of what you are doing.
Cheers,
Anna
