Hello, how can I create an Assembly of an air fan?
How should I define the constraints in order to make it turn?
Use the Advanced Editor link in the top right of the dialog box to be able to post files.
I would also suggest going thru the SolidWorks Tutorials under Help. You will find an Assembly tutorial under Set 1.
To make your fan blades turn you will want to model them seperate from the shaft assembly. I think you need at least one more part file for just the blades.
Cheers,
Anna
Can you post the parts/assembly (pack-and-go) to give us an idea of how to help you?
