5 Replies Latest reply on Jun 12, 2012 11:37 AM by David Brown
    Dual Dimension formatting for slot hole callouts
    Jared Mikasa
      Hi Everyone,
      I'm trying to figure out how to format dual dimensions on slots.  I know how to position dual dimensions for all features except for slots.  Here is how my dimension currently looks:
      I would like the dual dimension to appear above the primary dimension.  Does anyone know how to do this?
        • Re: Dual Dimension formatting for slot hole callouts
          Brian Lindahl
          I tried and got the same thing.  As a work-around, I came up with this:
          Part 1 is the dual dimensioned slot, just like you had shown.  Part 2 is the diameter of the slot in dual dims, and 3 is the length in dual.  Part 4 is not a dimension, but rather a linked note, referencing part 3 and 4 of the image.  After creating Note 4, hide (View, Hide/Show Annotations) the RD3 and RD4 entities.  (Dim 1 is not required for anything).  This remains parametrically driven by the model, which is good, but it's just a bunch of extra steps to accomplish.  Also - DON'T DELETE THE REFERENCE DIMENSIONS!!!  They should only be hidden.  If they are deleted, the reference dimension names can get recycled, and then the note is linked to something new.
            David Brown
            I am trying to do a similar type of formatting with dual dimensions, my quick workaround was to finding an old autocad dwg with the formatting I wanted and opening/copying the dimension from the autocad drawing. Unfortunately the format painter doesn't transfer stacking over to the solidworks dimensions so I had to modify the imported dimension. Certainly not the best solution but works.
