I'm trying to capture the Rename File event in EPDM 2010 and then getting the UserID of the person doing the rename. I'm using this VB.Net code:
Public Sub OnCmd(ByRef poCmd As EdmCmd, ByRef ppoData As System.Array) Implements IEdmAddIn5.OnCmd
If poCmd.meCmdType = EdmCmdType.EdmCmd_PreRename Then
Dim vault As IEdmVault11 = poCmd.mpoVault
For Each cmdDatum As EdmCmdData In ppoData
Dim id As Integer = vault.GetLoggedInWindowsUserID(vault.Name)
But the code bombs because of the call to GetLoggedInWindowsUserID. (If I comment this line out, it runs fine.) The error I get is:
We are not using Windows to manage our logins, we are using Enterprise PDM logins.
Am I calling this wrong? Any other ideas? Thanks!
Well, I changed the third line to:
Dim vault As IEdmVault5 = poCmd.mpoVault
and now it works!
How could this be?!?! The help file lists the function as:
IEdmVault11::GetLoggedInWindowsUserID
and IEdmVault11 should inherit from IEdmVault5, so why didn't it work?
