2 Replies Latest reply on Jun 8, 2012 10:47 AM by Jason Barr
    Property Tab Builder in custom properties
    Jason Barr
      I'm finally trying to set use the property tab builder and I'm having an issue. Is possible to make the properties show up in the custom tab instead of the configuration specifc tab?  Our drawing title blocks are set up so that they are linked to the properties of the model view.  If the part happens to be sheet metal, the first view is the flat pattern which doesn't have any properties (kind of pointless to switch back and enter the same properties in each configuration).  If the properties went in the custom tab, then it would work.  Am I missing something?
