I'm having issues defining bearing load. The error says "Z axis of coordinate system must be coincident with the axis of the cylindrical faces". The cylindrical faces were built from the z axis of the coordinate system....so we can't figure out why the error is occuring. This was an imported model. When we quickly built a "donut" test model, it worked fine. Any help would be appreciated.
It may have been built from the z axis but it was then exported and imported prior to making the user defined coordinate system. That may have caused a misalignment of the temporary axis and the bore face. Did the solid Import? If so, I might try filling in the imported bore and cutting the bore again in solidworks.
