Hi all,
I am having a lot of trouble folding a 45 degree bend (See attached Detail Drawing, Parts and Bend table). I am using a bend table and I cant get close to the dimension of the brake press bend sizes without a error ocurring in the mitre flange.
If someone could take alook at the 3 attached documents and tell me where I am going wrong that would be appriciated.
Good morning Jeremy,
To give an accurate answer I would need to see a formed view that would show me what your dimensional intent is for your parts. In other words, I need to see what your actual part dimensions need to be.
In the flat Solidworks is showing the positions of the bend centerlines for your brake operator, those are calculated from your bend table as shown here. Looking at your bend table I see the bend deduction is larger for the 45 degree bend than the 135 degree bend, that appears to be incorrect. If you're using an Amada press brake I can understand how these two were inverted.
To an Amada control, a 90 degree bend is 90 degrees. While a 45 degree bend is entered on the control as 135, or 180-45. A 45 degree bend is 180-45=135 degrees.
I would suggest using .42 as a K factor for all bends except for the 90 degree, I would assume you know what your actual deduction is for a 90. I remodeled your part using a .42 K factor and the flat results are shown below.
