id like to know if it is possible to export a file to autocad and how?
Unless I am missing something here......All you need to do is SaveAs and change the "Save as type:" pull down menu to DWG (*.dwg). Right below that selection is a button that says Options... Click on the Options... button and select which release of AutoCAD you want to export to. Usually all I have to change is the release version, the rest of the default settings work for us.
STEP OUT A MODEL FOR 3D
or save as for 2d drawings
