I am trying to do a bulk check into PDM works. If I have the assembly open, I can go check it in like normal by right clicking in the proper project file in the vault. I click to check in active document. I then try clicking the button down below that indicates to find and include associated drawings. However, nothing happens when I do this. I figured its a directory issuethat it can look in the proper place on my hard drive to search for the right files. In my vault properties I can go check the box to include drawings and I added a search folder but then it wants to do a long drawn out process when I click to check in....and I dont necesarly want it to include drawings everytime...It has worked beforre in the past but I had to reload PDM and lost my previous settings...Any help would be appreciated....I also have a question what if I am doing bulk check in through the admin tool, can it automatically find any referenced drawings from the assembly? I can manually drag them over to be added but I like the idea of only adding the referenced documents.
are you saying this dialog box doesn't appear after selecting "drawings"?
not sure what would cause this.
i don't use bulk checkin so no help there.
you probably won't like what i'm about to say next but here goes.
for as long as i've been using pdmw (since '03) i ALWAYS checkin from open drawing.
i always like to give the drawing one last look before it goes in.
