Guys,
I have tried this in the past and been unsuccessful, we've had customers send us the "nest" files per say and would build up anything around it that we required but I am looking to stray away from that and be able to do it myself. Before I go further I must note I'm pretty amateur when it comes to solidworks, most of what I do is machine and panel layout... a lot of holes and cut-out patterns on 2D surfaces usually so apologies for my ignorance! Now on to the question at hand...
I've attached a picture. But basically what I have is a part (for this we'll say a smoke detector ) so you can visualize the surfaces, empty spacing, etc that type of part might have. I can set the part in the block, and remove what I need for a nest there's just one thing... it leaves material where the part is hollow. I am assuming I need to either A) fill the part to a solid or B) tell mold tools (or use a different function all together) to remove that as well. I dont know how to do either, and maybe I'm not even thinking correctly. For what it's worth, with some searching I was able to find and use the "shut off surfaces" function, but only to an extent, the part has a lot of uneven and off surfaces and again... I really dont know exactly what I'm doing, or what I should be doing. Thanks for any and all help!
Welcome to SolidWorks forums Mike.
Using Combine feature might be help. Check here for some example and explanation.
Please use "advanced editor" in case you want to attach any files.
You might also find this post helpful for your future reference.
