Recently, a co-worker of mine started using a vault that I had set-up a while ago. He is getting the error "
There was an error opening this document. This file cannot be found" when he tries to check a drawing into the vault. I have the vault set to auto-create a PDF at check-in, and I think the error has something to do with Adobe trying to open the PDF file at check-in. Is there any way to prevent adobe from starting when checking drawings into the vault?
Thanks all,
Dan
Hi Dan,
Have a look at KB Solution S-057357 and see if that helps
Most likely related to spr 601015
Regards,
Larry Z
