I'm a student and a new user of Solidworks, here is my question:
I'm importing a curve through XYZ points and then converting these points with "convert entities" for my sketch. I would like to know if, when I'm converting these points, the resulting curve is a spline or is made of several straight lines? I need that answer because I want to be pretty accurate and straight lines could not be sufficient.
Thanks in advance, best,
Bertrand
The converted entity will be a spline. I use this technique for bringing in NACA data on airfoils.
Cheers,
Anna
