How would I mirror the other right half of this part (using front view)?
PS. I am currently using SW 2010. I will not be able to open up files from newer version.
Why not just do a Mid Plane Base Flange Extrude?
If you want to use Mirror you need to Select the Body in the Cut List or Body folder in the feature tree.
Cheers,
Anna
Anna,
What I want to do is mirror the right side of part to make into U shape, not extending the part by using MID PLANE option.
Jef, mirror the sketch.
Chad,
This would be great if there is no feature on the part. However, what if there is a hole on one of the flanges?
Mirror Body will work for you. It is not in the sheetmetal section, look at Features then mirror.
Your bend allowance needs a bit of attention, use something other than 10.0"
Chad
I agree. With such a simple part there is no real point in trying to mirror it as a feature. If you did want to do it as a feature, do a thin extrude, mirror, the convert to sheetmetal. SW2012 will mirror sheetmetal but can't recall if 2010 will.
Chad
