I have two reference points in 3D space. Then I connect them with a straight line using 3D sketch. Simple enough, but when I modify the dimensions of the points the line endpoints do not follow causing me to re-edit the sketch and aligning them again. I can only align them by dragging, no relations show up to make these permanent. Any suggestions?
Don
I get the same thing. If I make the line from reference point to reference point, it does not update.
If I create a 3D line from vertice to vertice, it will update. A 3D line from a sketch point to a sketch point will also update. Doesn't matter if it's a 3D sketch or 2D sketch in the part, the sketch point still works.
That may be your best workaround. Create a sketch with a sketch point in the part.
Dwight
