hi all,
i hope the answer to thsi questions is YES!
can one control the value of a global variable using configurations or a design table. i want a global variable to change its value depending on a configuration. referring to image below, the "125" should be "85" for the 85C delta config and for the 125C delta config it needs to be 125 and so on...
Yes in the design table in the comum header type: $value@variablename@equations
