3 Replies Latest reply on May 23, 2012 10:55 PM by Jerry Steiger
    Memory
    Emil Tietje
      We recently upgraded to Win7 x64 with 12G of ram.  SolidWorks 2012, plus other programs, do not appear to be using more than 4G.  Currently, I am running a simulation and would expect SolidWorks to use more then 4G.  Is it possible to increase the ram that is available to SolidWorks?
        • Re: Memory
          Wayne Tiffany
          I don't know that you can force SW to use more ram.  I have seen my ram usage go to 14.2 Gb total system when I loaded large models.
            WT
          • Re: Memory
            Anna Wood
            SolidWorks is using as much as it needs.  If it needs more it will use it.  I have opened up models that used 20 gigs of RAM.
            Cheers,
            Anna
            • Re: Memory
              Jerry Steiger
              Emil,
              You might want to ask this in the Simulation forum. It may be that Simulation has some options that control memory usage, since memory was a big problem for simulation programs in the old days. I know that ANSYS sometimes seems to start using swap space even though I still seem to have lots of memory available. I haven't followed my own advice and tried to find settings that I can change to improve the performance.
              Jerry Steiger
