ok, so i have a rolled piece of steel. has 6 different sizes (configurations) plus a flat pattern under each configuration. when i edit a dimension in the design table, the rolled configuration updates fine. but the flat pattern will not update until i re-link the dimension to the parent configuration. (notice i say re-link, because it is already shown as being linked to the parent configuration.
just wondering if there was a way to prevent me having to re-link an already linked dimension every time.
thanks in advance
have found that, after changing the value in the design table, if i load the formed configuration, then load the flat configuration, all updates fine. quickest work around i have found so far.
