Hi everyone,
In the attached file i want to cut the split spline i made and remove that surface, but it wont let me cut the curved ones. Someone tried helping me and I so that it is possible to do, but he has the 2012 version and i use the 2011 student. I did see that he used untrim surface after the offset, i dont know why or if it make a difference.
What can i do?
Hi Shar,
Ive attached the Model in your previous post.
To trouble shoot these types of issue.
1. First do "Thicken" operation and see is covering the correct volume to be removed or not.
2. if the volume to be subtracted is not covered, extend the surface accordingly.
3. then remove thicken and do thicken cut.
or after step 2 you can do a boolean operation (Subtract).
Regards
Ravi T
