I am running into an interesting issue that does not allow me use external reference geometry from parts in an assemby as external references. In this case I have a top level assembly (top_assy) that contains 1 sub assembly (sub_assy1) with parts part_sub1 and part_sub2. I am trying to create a part (top_part1) in context in the top_assy in which I need to access geometry information from part_sub1, part_sub2, etc.
I have done this many times in the past, but ran into a problem recently that would not let me access the external reference data. I was in "edit component" mode for top_part1 and trying to use "convert entities" and "offset entities" from parts part_sub1, etc. When in convert entities window I select geometry from the sub_parts, but nothing would be added to the selection window. In a couple of cases I would get an error that told me I was trying access properties from another assembly and that I could not use it.
I was able to start from scratch doing the same process and the problem was fixe, but I need to know when and why I cannot use external reference data in certain circumstances?
Any suggestions for configuration or setup with assemblies that would cause such issues?
Deb,
Have you checked this option? Also see where the one to Allow multiple contexts is set. You need to be careful with that one, but sometimes you do need it on.
