I would like to convert the roof of the console to sheetmetal? cant seem to figure it out
and is there a easy way to make a drawing of all the flatpatterns without going to a dxf file first?
thank you
Dave
thank you
Dave
Try using the Save Bodies > Create Assembly function before converting the bodies to sheet metal. This will create an assy of parts as opposed to bodies, and the Insert Bends or Convert To Sheet Metal tools can be used on those parts to create sheet metal parts.
The original multi-body part remains associative and is used to control the shape and size of the parts, but the flat patterns of the parts become available separately for drawing views.
Use the Insert Bends tool, and select a straight edge for the Fixed face or Edge field.
FYI ... you don't need to compress (ZIP or RAR) when uploading a single part, the forum does that automatically.
Also many people don't have a RAR decompression utility.
