I have my variables set up in Enterprise for the attributes in the AutoCAD title blocks. The problem I am having is if I switch to a different size title block in AutoCAD the attributes are all dots (Default Value (.) in the new title block which write back to the card which in turn overwrites the existing info in the data card. How can I stop the acad file from updating the data card?
We are not using the AutoCAD addin.
Bill
I do not know of a way to make it one-directional.
I believe you will need to re-enter the appropirate info into the new title block in acad before you check it in.
