3 Replies Latest reply on May 11, 2012 3:06 PM by Troy Peterson
    Datum Target Symbol
    Blair Legge
      Im wondering if there is a way to change the Datum Target Symbol. I've only seen a way to change the Datum Feature but i want to use a symbol that looks similar to the dowel pin symbol (See Insert>Annotation>Dowel Pin Symbol). Im new to solidworks so please dont be shy about going into details!
      Blair
        • Re: Datum Target Symbol
          Troy Peterson
          That symbol does not sound like any symbol in the ANSI standard. If it is part of a different standard you will need to change to the other standard in the Options -> Document Properties -> Overall drafting standard and it would be available to you.
          *edit - if this is a custom symbol then you could make it into a block and insert it into the drawing that way.
