I am having trouble flattening the attached part file as it loses segments of it. I was wondering If anyone can help me with this plz?
Hi again people,
I have a new problem with this sheet metal part. When I import the Flat Pattern view of the part in the drawing, the bend lines don't show and I have checked the "Display sheet metal bend notes" option in the file propertiers and it's enabled so I don't know how I can get the bend lines shown on the flat pattern
John,
I don't think you got my question right. I contacted the Solidworks support line and below is theri solution which I couldn't quite understand how to apply to my Part:
"In order for SolidWorks to show bend lines, there are a number of conditions that have to be met. In your case, the lines in the sketches are not parallel, hence the side walls will be slightly twisted. I can see that you are using Fixed relations, and the radii of the arcs are undefined. Please can you use normal sketch relations to fully constrain the sketches? You might be best off using 2d sketches rather than 3D ones since they are essentially 2D anyway"
Good afternoon Amir,
Sorry about that, I think your question was right it was my perception that was wrong.
Lofted bend normally don't show bend lines you need to create your own, flatten the part and add a construction line in the center of the bend area and it will work, however you need to add bend notes etc....
Later,
John
I am not sure how sheet metal bending works in real life so I wouldn't know and where to manually add the bend lines and etc,
Well this is one step closer to what I need but it is only shwing the bend line, but nut the dimentions such as bend radii and etc!
Try this one,
Later,
John
