How do you get the weldment cutlist to add a line for sheetmetal components created in the weldment. I have a structural steel frame and added some sheet metal components to it using a surface extrude and trim and then converted them to sheetmetal. They show in the cutlist in the feature tree but don't show up in the cutlist when I add it to a drawing. (I have clicked update)
Brian,
As long as the sheet metal parts were definitely converted, it should show up after hitting the update button. If they were converted, the new Sheet Metal feature as well as Flat Pattern feature would show up in the feature tree. Double check it there first, then check under the Cut List folder to make sure the body shows up. If these look fine, could you post the model?
