Hello SW -community,
Can anyone recommend what setting should I tweak in order to make that image more photo-realistic?
I would like to achieve a smoother finish without that graininess. In the images shown i have used the MATTE ALUMNIUM APPEARANCE.
Thank you in advance!
Hi PetKo. That's a good-looking image. I'm not an expert, but I can suggest a couple of things that might give the aluminum a more realistic appearance.
1) edit the appearance and reduce the scale of the sample a little.
2) edit the appearance, go to the surafce finish tab, enable displacement (have to have photoview loaded for this to show up) and set the height to a low value
3)Instead of Matte aluminum, try using aluminum powdercoat (that's in Painted appearances).
4) add a low brightness dark-blue directional light to the scene. (This will cool the shadows a bit so that the finish doesn't pop so much against the surrounding materials and background)
