We are about 2 weeks away from implementing EPDM. One of the last things I am trying to sort out has to do with the status of our parts. We will only have two states, work in progress and released.
What I want to do:
Every Part/Assembly would have a custom property called "Status"
I want "Status" to be linked to the workflow state in the EPDM system.
This "Status" property will then be called up in our title block.
What I can't figure out:
How to link custom proerty "Status" to the EPDM workflow state.
I guess we could just avoid using the workflow states all together for this purpose, but I figure we can use a function already built into the system and may have a use for some the transition fuctions.No sense have (2) different sets of staus data.
Regards,
Ryan
You can use a transition action to write a value to a variable, which is mapped to the custom property. Whenever a file goes into a state, the action changes the 'Status' variable and the property in the file would update because of the mapping.
