hi everybody
when i use an item from solidworks toolbox i want to be able to save in the folder of the assembly i used it in and that the link be to the saved part not to the library
can it be done and if it does if i try to open the assembly from an other computer on the network will it find the saved item or it will link to an unknown item in the library
Hi Hijazi,
Have you taken a look at the User Settings tab in the Toolbox Configurator? There is an option in there to set a folder to have part files created when they are used in Toolbox. You would have to change this directory each time you want the part saved to a new location based on the assembly though. If you make the save location on the server then all users with access to that server location will be able to open an assembly and it'll find the hardware.
