What thickness and precision do you all use for sheet metal models? What are the ramiifications?
We design in millimeters and use sheet metal gauges currently common in the US. For our sheet metal models, it is my preference to model a sheet metal thickness to the nearest tenth of a millimeter for the thicker gauges, to the hundreth for thinner stuff. I keep the model thickness inside the thickness tolerance. I might try to hit on the low side, since most sheet metal runs light.
I prefer to do this to keep the part dimensions easy. You can't always design on one side of the sheet - many times the thickness gets into the part dimensions.
Others in our department prefer to use the 3-place inch value shown in the charts and convert that to millimeters, no matter how many decimal places produces. Still others, more middle-of-the-road, prefer a millimeter value to two places as shown in some gauge charts.
Dwight
Whatever you decide we, as a manufacture, will deal with. We re-model most every customer part anyways. The thickness is not so much as issue as all the other rounding errors most everyone models with.
i.e, .125 in the SolidWorks part model will be shown on the detailed slddrw as .13, etc. We will also model to take advantage of MMC conditions, etc. There is cut mis-matches to be considered for in progressively stamped parts. Plus many other manufacturing considerations that we may tweak a manufacturing model for to meet the customer requirements.
We inspect to the dimensions on the drawings. We re-model to the dimensions on the drawing (no rounding errors, lots of trailing zeros) with whatever thickness of material we will be getting. We rarely work with stock gage material and get most everything from the mill at +/-.002-.003 thick, so have a bit of an advantage over folks that use stock gage thickness materials when working to close tolerances.
The only time the thickness can become an issue is if you need close tolerances and you are mixing dimensions to the sides of material and have not built in enough tolerance to accomadate. Be aware of that and leave adequate tolerance and it will typically not be an issue.
FWIW, my perspective on things.....
Anna
