I want to get Old version of catia file which is part of epdm vault. It shows history in vault but I could not get it. Is there any possible way to get the same ?
Hello Jagandeep,
You meant to access the old versions / revisions of a file ? you could try actions > versions > pull down menu.
This will not be greyed out unless you are forced to use latest version of the files.
Hope this helps.
Regards,
Raghav.
Get Version menu items is not available for Catia files. It only works in case of Sw/Excel files
Jagandeep,
Currently EPDM supports and manages only SolidWorks,Inventor, Pro Engineer / Creo & Solidedge files.
I guess other files can only be dumped into the vault cannot be managed.
So no luck of managing Catia files apart from dumping into vault.
In the History select the version you want and then click on the "Get" button.
You must also make sure that you do not have the files open at the time - Windows will "Lock" the file if it is open.
Hello Jagandeep,
Hope this helps.
Regards,
Raghav.
