Hi All
I've created a Master model to create the overall shape of a plastic enclosure, then used Split feature to save off front and rear halves. Then added all the necessary detail to the two halves in their individual part files. And made an assembly from those part files.
Then, in one of the halve's part file, I created a new configuration. Clicked the default configuration, Control-C, then Control-V. When I hit Control-Q, all the features turn red. The very first feature (where the part was pulled from the master model) gives the error "The Base Part Has No Solid."
I've attached some pix. Does anyone have any idea what that means, what's caused this, or how to fix it?
Actually, now even the default configuration is doing this, and "Reload" does not solve it
Closed everything, Re-booted SolidWorks. The part comes in ok, with all features intact. Soon as I hit Control-Q, it is destroyed.
Tried this on the rear half, and it still works fine even after creating a new config and hitting Control-Q.
When I "List External References" on the failed first feature, it points back to the master model, and says
Data Status Referenced Entity
Solid Body In context Solid Body of Part A(master)
Feature In context Split 1 of Part A(master)
Very confused and would appreciate any insights.
Problem solved.
I had locked all references. Then when hitting Control-Q (force regen) the features failed.
When I unlocked all references, hit Control-Q, all the features resolved.
I guess it could see the master model once references were unlocked.
I had locked them, because I put both parts in an assembly, and referenced each other for features in both.
If references were unlocked, and I moved the parts in the assembly (to see the motion between the two), those referenced features would fail.
So had to keep references locked on both parts while working on them.
Although now, 3 months later, I can't recreate the probelem even when locking all references. It's fixed itself somehow.
Thanks Mark, Deepak, Jerry and Jason for your time on this.
