Hello All--
I am trying to create a connection with two ferrules and a gasket between them. We use a sanitary clamp to secure the tubing. I can insert one ferrule and a gasket, but I am having trouble with inserting the second ferrule. When the second ferrule is inserted, It snaps incorrectly. Does anyone have some suggestions? I am using Solidworks 2012 sp 2.0.
Thanks.
--Chris
Hello Chris,
This is the way I do it. Make a separate assembly and add your 2 ferrules and gasket and mate them together in the proper orientation. Create a route point using the route point of the gasket. Create 2 connection points using the connection points of each ferrule. Then make a design table so you have all the sizes that you will require. You can use this assembly as a library assembly and insert it as many times as you want (you can also add your clamps to this assembly so they get included into a bill of material).
Another way is to add 2 connection points to the ferrule and to the gasket (MAKE SURE THE ROUTE POINT IS IN BETWEEN THE 2 CONNECTION POINTS) then drop all 3 into a route with some space between them then right-click -> remove pipe on both sides of the gasket.
