4 Replies Latest reply on May 1, 2012 6:36 PM by Darren Marchant
    Can cutlist metadata be config specific?
    Darren Marchant
      Hi
      I have a 3 body weldment with 2 configs. The only difference between configs is the length of the pipe between the 2 end fittings.
      So i need 6 part numbers,
      1.  1 for each type of end fitting. this stays the same. This is in the cutlist metadata.
      2.  1 for each welded assembly. This always stays the same within each config. This is in the file properties.
      3. But i need two parts numbers, 1 for each length of pipe, to appear in the weldment cutlist. these would have been in the cutlist metadata.
      But it appears that cutlist item meta data is not able to be made configuration specific. ?
      Any ideas?
      Darren
