I have an external vb.net app that previews Windows files in the same way Windows Explorer sees them. See code below:
References:
Microsoft.WindowsAPICodePack.dll
Microsoft.WindowsAPICodePack.Shell.dll
Private Function GetWindowsPreviewBitMap(strFullFilePath As String) As System.Drawing.Bitmap
Dim BitMapResult As System.Drawing.Bitmap = Nothing
Dim ShellItem As ShellObject = Nothing
If System.IO.File.Exists(strFullFilePath) Then
ShellItem = ShellFile.FromFilePath(strFullFilePath)
BitMapResult = ShellItem.Thumbnail.ExtraLargeBitmap
Return BitMapResult
End Function
This function works great....Except in the Vault where EPDM appears to have a grip on the shell.
I end up with icon displays in my app when I point to a file in the Vault. I don't want to write a separate previewer for AutoCAD,SolidWorks,PDF,Visio,Word,Excel,Powerpoint,Publisher,etc etc.
Any ideas out there?
Kent Keller
Software Applications Engineering
Westport Shipyard Inc.
Hi Kent,
Does this happen even if you have the version locally cached?....Try performing "Get " operation and then running te code.
Regards
Ravi T
