Hello all,
I have a unique request from my manager that I haven't been able to solve. I've been asked to create a weldment cut list, but the twist is that even though it consolidates equal structural components into one item with quantity of two, we need to break every item individually with quantity of one (example below);
Item Description Length QTY
1 c4x7.25 14'-7" 1
2 c4x7.25 14'-7" 1
Is there a way to achieve this?
Steve Zema
I've received a solution! In the weldment, expand the cut list, then expand each sub-cut list, then drag each member to the upper level (make sure to uncheck "Automatic" to disable update. Then you can right-click each member and add to cut list for each individual componet.
Thanks to all for the assist.
