Hello All--
I am working on creating some sanitary elbows and I am new to solidworks routing. My company use tube for the most part and we do not bend the tube. I tried using solidworks routing for tubes, but found it limited because I did not have the option to work with tube elbows separately. We weld the tube fittings to our tube assemblie. To do this I have jury rigged the piping portion of solidworks to accomadate the different tube and tube fittings. Then I changed the schedule property to wall thickness and the specification to weld grade of material. I am working on creating a tube butt weld elbow that is longer than a standard tube elbow (short elbow). This elbow has straight tangents on the end. I have not been able to get solidworks to recognize this geometry. Has anyone had any success with this type of fitting? Attached is the fitting I am attempting to use.
Note: the file attached has the tangents set to .001" because I would like to combine the short and long elbow configurations into the same file.
Thanks.
--Chris
So except for yours being with a groove and in Imperial and mine without a groove and in metric there's no real difference, correct ?
You mentioned that you hadn't been able to have SW recognize straight tangents on your elbow.
Now English isn't my first language, which is why I wanted clarification to make sure I understood you correctly.
As you can see in the following picture
It all boils down to where you place the Cpoints. On the end of the elbows, the end of the tangent lenghts or even inside of the tangent lengths, if you want socketweld instead of butt weld.
