1.Crete part > part drawing >check in > Change state( for Approval)
After approval one approval folder gets cretaed in that PDF get created.for second approval 2nd revision of pdf gets created
In approved PDF Folder I see Both PDFs, But I want to display only the Latest Pdf(Revision)
Is there any solution,Please help me out?
Regards,
Mayuresh
Hi Tim,
Yes that can be an easy solution.
I am adding the dispatch which works fine.
and one more thing...is there any way i can make the dipatch not to throw error when a file is not found.This will happen when file is added for the first time.
Hi mayuresh,
find the attached file.
1. This assume rev character is present before the dot.
2. Status is added to Data card
3. auto transition allows file if status is OBSOLETE
eg.: dispatch-A.pdf
forum-B.pdf
Solidworks-C.pdf
You can add this dipatch to ADD file Action for a particular folder name.
