I create the split line to show the parting line in the part, I want to export the part to IGES file with the split line in. Somebody know how to do it?
If the surfaces are split and you save a iges you will see them when they import the iges into there software!
I do this all the time for machining in my CAM software, have since SW 97+.
Do you have any surfcae bodies hidden in the surfcae body folder in the tree, if there are and hidden they will still be included in the iges, you need to delete the surface bodies from the folder then save the iges, there will be a deleted body feature at the end of the tree that if you need back you can unsuppress.
I forget this alot too!
Did you actually use the Split Line command? That would split the faces, creating new edges which will be included in the IGES file.
Or are you talking about showing the Parting Line feature in the IGES file?
