I have a DT with 2 configuration and when I remove a configuration from DT all the dimensions of the removed configuration keep the specific color and when I try to edit the dimension sw display the same message as configuration continue to exist in dt. Even if I close file and open again nothing change.
The only solution that I founded till now is to save DT, delete it and reinserting from saved file. If anybody has a solution for this issue please help.
Faur,
Have you removed all of the uses of that configuration?
Meaning every where that specific config is used are they changed to a different config.
