I want to measure the acceleration of the slider (orange color) that moves along a table (green one). The green element rotates around an edge of the fixed table (red one). If the slider has a constant speed, with respect to the green element , the acceleration should be zero. And it is, but only when the green element does not move. Do you have a suggestion on how to measure the correct acceleration of the slider? The model is made in SW 2010 x64. All the best!
In item 1 you say you have defined a linear motor with a constant speed to move the slider. This is not what was defined in the files you sent. The linear motor starts at 1mm/sec at time zero and as 5mm/sec at time 5 seconds, so the motor is not moving at a constant speed.
Yes there is a way to define the plot to measure the acceleration of an object with respect to a specific element. Just read the Help file. Part of the problem is that you ploted the acceleration of the motor rather than the slider.
The final part is that even if you define the plot of the acceleration of the slider relative to the ramp, it will not be zero when the slider moves with constant velocity along the ramp, while the ramp rotates around the pivot. As this is a physic problem, if you hold the slider in its start postion by setting the linear motor to zero speed, have the ramp rotate, and then plot its acceration relative to the long demension of the green ramp part, it is about 2.4 mm/sec^2, which is the centripital acceleration. As centripital acceration is in the direction of the pivot, and a function of the radius, the acceleration of the part will not be zero.
Once you go back and fix the linear motor and plot definitions, you will get the proper acceleration of the slider. It will not be zero and will not be constant.
