When you say "develop" do you mean you need to flatten this
surface? And this would help you "draw" the label? This seems to be
a simple surface that you could use the sheet metal functionality
to get the flat of the surface you have drawn.
Ken Maren
Muderlak Design
www.muderlakdesign.com
Ken Maren
Muderlak Design
Thanks, ZECA
The only surfaces that you can put a sticker on without stretching or puckering are flat, cylindrical, conical and extruded/ruled surfaces.
These kinds of surfaces can be flattened in SW, although not in their surface state. Flattening can only be done on sheet metal. Lofted bends, an extruded base flange or a revolved thin feature with insert bends are techniques that can be used to flatten geometry.
