Hi all, I have an assembly which has a foam gasket and after assembly the foam gasket will be compressed around the perimeter against a metal wall. The foam gasket will be visible from the operning in the metal wall though. I'd like to show this in my Solidworks assembly, but I have no clue how to accomplish this feat. The attached picture should help explain the situation. Do any of you guys know of an easy way to do this?
Andy
Andy,
You could create another configuration of the gasket in the compressed srtate and swap that out to the other config in the assembly.
