Toolbox with Configuration Specific Property
Question asked by RICK ENCELLO on Apr 17, 2012
Latest reply on Apr 17, 2012 by Scott McFadden
Has anyone encountered problems using Solidworks 2011 Toolbox with a customized swbrowser? We have a custom swbrowser that we added Material and Finish to the database. The issue we have is I was able to create all our fasteners as individual parts with one configuration. And with in each fastener, it contains Custom Properties of Doc. Number, P/N and Description and on the Configuration Specific Properties I have Material, P/N and Description. I've check all files prior to vaulting into Smarteam and they contain all necessary info. When I pull out of Smarteam manually, all Custom and Config Specific properties are all intact. But once I use Toolbox with Smarteam Integration on, it does a file copy but the Configuration Specific Property Desription gets erased. Again if I pull it mannually all info is intact. So the question is if anybody is encountering this same issue and if anybody has found a resolution to it.
