I was given a bike model made up of many surfaces and was given the task to make it into one solid body with a thickness of 2mm. I tried to knit all the surfaces together and use the thickness command, and thickened individual pieces together and merged them, but there are still some pieces of the bike I cannot form into a solid body and/or give a thickness to. If someone could provide alternate methods to help me make the bike model into one solid body and have a thickness of 2mm it will be greatly appreciated.
Thank you for your time,
Grace
Hi Grace,
You might have success if you instead knit all the surfaces together and then cap the ends and make a knitted solid - then instead of thicken try to shell.
Regards
Mark
