I am trying to run a study in which a liquid flows through one inlet and two symmetric outlets
In FlowXpress
Can anyone offer some solution?
In FlowXpress
FlowXpress only allows one inlet and one outlet. the trick is to make your two outlets look like one, without affecting the flow in the areas of interest. You will need to model an outlet that combines the two, for example, a reservoir that has two inlets (fed from your outlets) and one outlet. Remember that all this needs to be done in a single part.
