4 Replies Latest reply on Apr 13, 2012 1:35 PM by Jeff Holliday
    parallels curves
    Luis Fernandez
      Hi
      I'm new in this forum.  i will tell you my problem.
      i would like to design many parallels curves with the function  "enlevement de matiere-balayage  and  repetition lineaire (français)".
      but  this channels are not parallel so i dont know what function i must use
      thank you very mach for your answers
      Best regards
      Luis ( France)
        • Re: parallels curves
          Kelvin Lamport
          To clarify, are you wanting to have a constant gap between the curved rods? That is impossible if you use a pattern because the inside and outside bend radii do not match.
          The only way would be to successively offset the path of each rod, but that would make each rod a different shape.
